[postgis-users] Increase query performance
Andreas Forø Tollefsen
andreasft at gmail.com
Tue Mar 8 05:04:21 PST 2011
Results from the EXPLAIN ANALYZE:
"Nested Loop (cost=0.00..1189.72 rows=3941 width=87790) (actual
time=7.091..2524830.264 rows=54145 loops=1)"
" Join Filter: _st_intersects(priogrid_land.cell, cshapeswdate.geom)"
" -> Seq Scan on cshapeswdate (cost=0.00..16.23 rows=22 width=87304)
(actual time=0.011..0.542 rows=72 loops=1)"
" Filter: ((gwsyear <= 1946::numeric) AND (gweyear >= 1946::numeric)
AND (startdate <= '1946-01-01'::date))"
" -> Index Scan using idx_priogrid_land_cell on priogrid_land
(cost=0.00..8.29 rows=1 width=486) (actual time=3.026..30.152 rows=1338
loops=72)"
" Index Cond: (priogrid_land.cell && cshapeswdate.geom)"
"Total runtime: 2524889.630 ms"
2011/3/8 Andreas Forø Tollefsen <andreasft at gmail.com>
> Hi,
> This query takes about 41 minutes per year. Doing this for every year from
> 1946 to 2008 takes a lot of time.
> The grid consists of 64818 cell polygons, while the country table has about
> 210 polygons.
> I will add indexes on year and date and try again. An do an explain
> analyze.
> Cheers,
> Andreas
> 2011/3/8 Paragon Corporation <lr at pcorp.us>
>> Andreas,
>> I don't see anything glaringly wrong with your query, but hard to tell
>> without seeing an explain plan or what you mean by takes a lot of time. Is
>> a lot of time minutes, hours, days?
>> How many records are we talking about here? What's the max number of
>> points you have in any geometry. Often times its just one huge mega
>> geometry with a 100,000 points or more slowing everything down.
>> Do you have indexes on your year fields and date columns?
>> Hope that helps,
>> Regina
>> http://www.postgis.us
>> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
>> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Andreas
>> Forø Tollefsen
>> *Sent:* Tuesday, March 08, 2011 4:15 AM
>> *To:* PostGIS Users Discussion
>> *Subject:* [postgis-users] Increase query performance
>> Hi all,
>> Another question on postgis query performance. I did some discussion on
>> the pgsql performance list on how i could increase the performance on my
>> server.
>> I did manage to increase the transactions per second, but came to the
>> conclusion that this did not help the ST_Intersection query which i was
>> trying to speed up.
>> Any suggestions on how to speed up this query? Basically i want to create
>> an intersection between a vector grid and country shapefiles. Then calculate
>> the area of all the polygons in the intersected table, and finally selecting
>> the country code for each cell which represents the largest area within each
>> cell. I does work as it is, but i would like to increase the speed. The
>> query which takes a lot of time is the ST_Intersection.
>> "PostgreSQL 8.4.7 on i686-pc-linux-gnu, compiled by GCC gcc-4.4.real
>> (Ubuntu/Linaro 4.4.4-14ubuntu5) 4.4.5, 32-bit"
>> "POSTGIS="2.0.0SVN" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
>> 2009" LIBXML="2.7.7" USE_STATS"
>> DROP TABLE IF EXISTS cshapesgrid1946;
>> SELECT ST_Intersection(priogrid_land.cell, cshapeswdate.geom) AS geom,
>> priogrid_land.gid AS divider, gwcode, gwsyear, gweyear, startdate, enddate,
>> capname, caplong, caplat, col, row, xcoord, ycoord INTO cshapesgrid1946 FROM
>> priogrid_land, cshapeswdate WHERE ST_Intersects(priogrid_land.cell,
>> cshapeswdate.geom) AND cshapeswdate.gwsyear <=1946 AND cshapeswdate.gweyear
>> >=1946 AND cshapeswdate.startdate <= '1946/1/1';
>> ALTER TABLE cshapesgrid1946 ADD COLUMN area float;
>> UPDATE cshapesgrid1946 SET area = ST_Area(cshapesgrid1946.geom);
>> DROP TABLE IF EXISTS pg1946;
>> SELECT * INTO pg1946 FROM cshapesgrid1946 a WHERE a.area IN (SELECT
>> MAX(area) FROM cshapesgrid1946 b GROUP BY divider);
>> CREATE INDEX idx_pg1946 ON pg1946 USING gist(geom);
>> Best,
>> Andreas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110308/cd16f74c/attachment.html>
