[postgis-users] make install as root on v1.5.2
Bill Teluk
bill.teluk at team.telstra.com
Wed Mar 9 18:58:09 PST 2011
I have installed PostGIS 1.5.2 on a PostgreSQL 9.0.4 (OpenSCG RPM) on an
RHEL5.5 system - the instructions in the included README.postgis indicate
that I should perform "make install" as "postgres" user. This didn't work
and generated the error below:
/bin/mkdir -p '/opt/postgres/9.0/share/postgresql/contrib/postgis-1.5'
/bin/mkdir: cannot create directory
`/opt/postgres/9.0/share/postgresql/contrib/postgis-1.5': Permission
denied
make[1]: *** [installdirs] Error 1
make[1]: Leaving directory
`/home/maptools/other/pgis_1_5_2/postgis-1.5.2/postgis'
make: *** [postgis-install] Error 2
I overcame this by performing "make install" as "root" user - I did this
because I noted that the online HTML documentation for v1.5 doesn't indicate
which user to install as - at least as far as I could see (ref
http://postgis.refractions.net/documentation/manual-1.5/ch02.html#id2630263
Is this a documentation error, or should I really be installing as user
"postgres"?
Thanks.
Regards, Bill Teluk.
View this message in context: http://old.nabble.com/make-install-as-root-on-v1.5.2-tp31112326p31112326.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
