[postgis-users] Problem with WKTRaster: cannot get raster type in database
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Mar 11 08:20:24 PST 2011
Is there any way I can see the list of file included in your kyngchaos package?
libgdal is the base GDAL library. rtpostgis.so is dependent on it and should be able to find it in the same folder or any lib search folder.
Pierre
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>bounces at postgis.refractions.net] On Behalf Of AJ7
>Sent: 11 mars 2011 11:17
>To: postgis-users at postgis.refractions.net
>Subject: Re: [postgis-users] Problem with WKTRaster: cannot get raster type in database
> Yes I do have the rtpostgis.so file in "usr/local/pgsql-9.0/lib", but I
>don't have any libgdal. where should I get this from? Is this why its not
>working?
>Pierre Racine-2 wrote:
>> Do you have the "rtpostgis" shared library in "usr/local/pgsql-9.0/lib"?
>> There should be "libgdal" as well.
>> Pierre
>>>Sent: 11 mars 2011 07:02
>>>Subject: [postgis-users] Problem with WKTRaster: cannot get raster type in
>database
>>>Hi,
>>>I installed postgis1.5 and the corresponding wkt package for the Mac OS
>>>Leopard 1.6...using the packages from kyngchaos. While I believe that
>>>wktraster has been installed properly (i.e. i could run the
>>>gdal2wktraster.py script on a tiff file), when I try to enable my database
>>>for the raster type support, this is not working. I get the error:
>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:32: ERROR:  could not
>>>access file "$libdir/rtpostgis": No such file or directory
>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:37: ERROR:  type raster
>>>does not exist
>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:45: ERROR:  function
>>>raster_in(cstring) does not exist
>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:58: ERROR:  could not
>>>I am try the following command:
>>>su - postgres -c '/usr/local/pgsql-9.0/bin/psql -p 5433 -d [dbname] -f
>>>/usr/local/pgsql/share/contrib/rtpostgis.sql'
>>>what is wrong here please?
>>>pg_config --libdir -> usr/local/pgsql-9.0/lib
>>>pg_config --pkglibdir -> usr/local/pgsql-9.0/lib
>>>really need help on this.Hope its a simple thing.
>>>thanks
>>>View this message in context:
>http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>>>in-database-tp31124425p31124425.html
>>>Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>View this message in context: http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>in-database-tp31124425p31126445.html
