[postgis-users] Problem with WKTRaster: cannot get raster type in database
AJ7 ackbar at ackadij.com
Fri Mar 11 08:23:25 PST 2011
Hi Pierre
I installed from here:http://www.kyngchaos.com/software/postgres
I already had GDAL 1.8 complete installed on my machine, so didn't bother
installing again. (all the installations from the link above worked fine).
Pierre Racine-2 wrote:
> Is there any way I can see the list of file included in your kyngchaos
> package?
> libgdal is the base GDAL library. rtpostgis.so is dependent on it and
> should be able to find it in the same folder or any lib search folder.
> Pierre
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>>bounces at postgis.refractions.net] On Behalf Of AJ7
>>Sent: 11 mars 2011 11:17
>>To: postgis-users at postgis.refractions.net
>>Subject: Re: [postgis-users] Problem with WKTRaster: cannot get raster
type in database
>> Yes I do have the rtpostgis.so file in "usr/local/pgsql-9.0/lib", but I
>>don't have any libgdal. where should I get this from? Is this why its not
>>working?
>>> Do you have the "rtpostgis" shared library in "usr/local/pgsql-9.0/lib"?
>>> There should be "libgdal" as well.
>>> Pierre
>>>>Sent: 11 mars 2011 07:02
>>>>Subject: [postgis-users] Problem with WKTRaster: cannot get raster type
in
>>database
>>>>Hi,
>>>>I installed postgis1.5 and the corresponding wkt package for the Mac OS
>>>>Leopard 1.6...using the packages from kyngchaos. While I believe that
>>>>wktraster has been installed properly (i.e. i could run the
>>>>gdal2wktraster.py script on a tiff file), when I try to enable my
database
>>>>for the raster type support, this is not working. I get the error:
>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:32: ERROR:  could not
>>>>access file "$libdir/rtpostgis": No such file or directory
>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:37: ERROR:  type
raster
>>>>does not exist
>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:45: ERROR:  function
>>>>raster_in(cstring) does not exist
>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:58: ERROR:  could not
>>>>I am try the following command:
>>>>su - postgres -c '/usr/local/pgsql-9.0/bin/psql -p 5433 -d [dbname] -f
>>>>/usr/local/pgsql/share/contrib/rtpostgis.sql'
>>>>what is wrong here please?
>>>>pg_config --libdir -> usr/local/pgsql-9.0/lib
>>>>pg_config --pkglibdir -> usr/local/pgsql-9.0/lib
>>>>really need help on this.Hope its a simple thing.
>>>>thanks
>>>>View this message in context:
>>http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>>>>in-database-tp31124425p31124425.html
>>>>Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>in-database-tp31124425p31126445.html
View this message in context: http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-in-database-tp31124425p31126499.html
