[postgis-users] Problem with WKTRaster: cannot get raster type in database
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Mar 11 08:35:52 PST 2011
Well I can't open those .dmg files. The only important thing is that the gdal library is beside the rtpostgis.so library and is named libgdal.so
Do you have that?
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>bounces at postgis.refractions.net] On Behalf Of AJ7
>Sent: 11 mars 2011 11:23
>To: postgis-users at postgis.refractions.net
>Subject: Re: [postgis-users] Problem with WKTRaster: cannot get raster type in database
>Hi Pierre
>I installed from here:http://www.kyngchaos.com/software/postgres
>I already had GDAL 1.8 complete installed on my machine, so didn't bother
>installing again. (all the installations from the link above worked fine).
>Pierre Racine-2 wrote:
>> Is there any way I can see the list of file included in your kyngchaos
>> package?
>> libgdal is the base GDAL library. rtpostgis.so is dependent on it and
>> should be able to find it in the same folder or any lib search folder.
>> Pierre
>>>Sent: 11 mars 2011 11:17
>type in database
>>> Yes I do have the rtpostgis.so file in "usr/local/pgsql-9.0/lib", but I
>>>don't have any libgdal. where should I get this from? Is this why its not
>>>working?
>>>> Do you have the "rtpostgis" shared library in "usr/local/pgsql-9.0/lib"?
>>>> There should be "libgdal" as well.
>>>> Pierre
>>>>>Sent: 11 mars 2011 07:02
>>>>>Subject: [postgis-users] Problem with WKTRaster: cannot get raster type
>in
>>>database
>>>>>Hi,
>>>>>I installed postgis1.5 and the corresponding wkt package for the Mac OS
>>>>>Leopard 1.6...using the packages from kyngchaos. While I believe that
>>>>>wktraster has been installed properly (i.e. i could run the
>>>>>gdal2wktraster.py script on a tiff file), when I try to enable my
>database
>>>>>for the raster type support, this is not working. I get the error:
>>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:32: ERROR: could not
>>>>>access file "$libdir/rtpostgis": No such file or directory
>>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:37: ERROR: type
>raster
>>>>>does not exist
>>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:45: ERROR: function
>>>>>raster_in(cstring) does not exist
>>>>>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:58: ERROR: could not
>>>>>I am try the following command:
>>>>>su - postgres -c '/usr/local/pgsql-9.0/bin/psql -p 5433 -d [dbname] -f
>>>>>/usr/local/pgsql/share/contrib/rtpostgis.sql'
>>>>>what is wrong here please?
>>>>>pg_config --libdir -> usr/local/pgsql-9.0/lib
>>>>>pg_config --pkglibdir -> usr/local/pgsql-9.0/lib
>>>>>really need help on this.Hope its a simple thing.
>>>>>thanks
>>>>>View this message in context:
>>>http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>>>>>in-database-tp31124425p31124425.html
>>>>>Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>>>_______________________________________________
>>>>>postgis-users mailing list
>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>in-database-tp31124425p31126445.html
>View this message in context: http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>in-database-tp31124425p31126499.html
