[postgis-users] Problem with WKTRaster: cannot get raster type in database
William Kyngesburye
woklist at kyngchaos.com
Fri Mar 11 08:41:14 PST 2011
GDAL shouldn't be the problem. This is OS X, and GDAL is a framework, so you won't see a library file in Postgres lib/ or /usr/local/lib. rtpostgis.so is properly linked to the GDAL framework.
It looks to me like it's /usr/local/pgsql but can't handle the symlink to /usr/local/pgsql-9.0. Or it doesn't like the mismatch? What about this:
su - postgres -c '/usr/local/pgsql-9.0/bin/psql -p 5433 -d [dbname] -f /usr/local/pgsql-9.0/share/contrib/rtpostgis.sql'
On Mar 11, 2011, at 10:35 AM, Pierre Racine wrote:
> Well I can't open those .dmg files. The only important thing is that the gdal library is beside the rtpostgis.so library and is named libgdal.so
> Do you have that?
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of AJ7
>> Sent: 11 mars 2011 11:23
>> To: postgis-users at postgis.refractions.net
>> Subject: Re: [postgis-users] Problem with WKTRaster: cannot get raster type in database
>> Hi Pierre
>> I installed from here:http://www.kyngchaos.com/software/postgres
>> I already had GDAL 1.8 complete installed on my machine, so didn't bother
>> installing again. (all the installations from the link above worked fine).
>> Pierre Racine-2 wrote:
>>> Is there any way I can see the list of file included in your kyngchaos
>>> package?
>>> libgdal is the base GDAL library. rtpostgis.so is dependent on it and
>>> should be able to find it in the same folder or any lib search folder.
>>> Pierre
>>>> Sent: 11 mars 2011 11:17
>> type in database
>>>> Yes I do have the rtpostgis.so file in "usr/local/pgsql-9.0/lib", but I
>>>> don't have any libgdal. where should I get this from? Is this why its not
>>>> working?
>>>>> Do you have the "rtpostgis" shared library in "usr/local/pgsql-9.0/lib"?
>>>>> There should be "libgdal" as well.
>>>>> Pierre
>>>>>> Sent: 11 mars 2011 07:02
>>>>>> Subject: [postgis-users] Problem with WKTRaster: cannot get raster type
>> in
>>>> database
>>>>>> Hi,
>>>>>> I installed postgis1.5 and the corresponding wkt package for the Mac OS
>>>>>> Leopard 1.6...using the packages from kyngchaos. While I believe that
>>>>>> wktraster has been installed properly (i.e. i could run the
>>>>>> gdal2wktraster.py script on a tiff file), when I try to enable my
>> database
>>>>>> for the raster type support, this is not working. I get the error:
>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:32: ERROR: could not
>>>>>> access file "$libdir/rtpostgis": No such file or directory
>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:37: ERROR: type
>> raster
>>>>>> does not exist
>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:45: ERROR: function
>>>>>> raster_in(cstring) does not exist
>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:58: ERROR: could not
>>>>>> I am try the following command:
>>>>>> /usr/local/pgsql/share/contrib/rtpostgis.sql'
>>>>>> what is wrong here please?
>>>>>> pg_config --libdir -> usr/local/pgsql-9.0/lib
>>>>>> pg_config --pkglibdir -> usr/local/pgsql-9.0/lib
>>>>>> really need help on this.Hope its a simple thing.
>>>>>> thanks
>>>>>> View this message in context:
>>>> http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>>>>>> in-database-tp31124425p31124425.html
>>>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> in-database-tp31124425p31126445.html
>> View this message in context: http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>> in-database-tp31124425p31126499.html
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
