[postgis-users] Illegal Byte Sequence
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Mar 14 03:28:21 PDT 2011
Hallo Andreas
May I guess you are running the trunk version.
I think it is related to tichet #808
http://trac.osgeo.org/postgis/ticket/808
One workaround is described in the ticket by creating the .sql file
without any encoding parameters and then change the first row of the sql
file to
SET CLIENT_ENCODING TO LATIN1;
before running it in psql
Another workaround is using an older skp2pgsql to create the sql-file.
PostGIS will load it in PostGIS 2 format anyway.
HTH
Nicklas
On Mon, 2011-03-14 at 11:11 +0100, Andreas Forø Tollefsen wrote:
> The error:
> Importing shapefile (1267 records)...
> Unable to convert data value to UTF-8 (iconv reports "Illegal byte
> sequence"). Current encoding is "UTF-8". Try "LATIN1" (Western
> European), or one of the values described at
> http://www.postgresql.org/docs/current/static/multibyte.html.
> Shapefile import failed.
> 2011/3/14 Andreas Forø Tollefsen <andreasft at gmail.com>
> Hi,
> I am trying to import this shapefile into a database on my new
> server:
> http://sedac.ciesin.columbia.edu/povmap/downloads/ds_global/imr_shapefile.zip
> While this was no problem on my old server running Windows
> Vista, i now have problems on my Ubuntu Server.
> My last server had the LC_COLLATE AND LC_CTYPE blank, while
> the new Linux has en_US.UTF-8 which seems to create the
> problems.
> I tried creating a new database on the new server with blank
> COLLATE and CTYPE, but it would not accept blank.
> Any ideas?
> Thanks,
> Andreas
> The old database had the following settings on Enconding:
> CREATE DATABASE newpg
> WITH OWNER = -----
> ENCODING = 'UTF8'
> TABLESPACE = pg_default
> LC_COLLATE = ''
> LC_CTYPE = ''
> CONNECTION LIMIT = -1;
> The database on the new server has the following:
> CREATE DATABASE priogrid
> WITH OWNER = -----
> ENCODING = 'UTF8'
> LC_COLLATE = 'en_US.UTF-8'
> LC_CTYPE = 'en_US.UTF-8'
> postgis-users mailing list
