[postgis-users] postgis raster : getting pixel value
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Mar 14 10:16:57 PDT 2011
See this tutorial:
http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01
search for "Intersecting the caribou buffers with the elevation rasters"
the query look like this:
CREATE TABLE resulttable AS
SELECT id,
(gv).geom AS the_geom,
(gv).val
FROM (SELECT id,
ST_Intersection(rast, the_geom) AS gv
FROM yourrastertable,
yourpolygontable
WHERE ST_Intersects(rast, the_geom)
) foo;
Then you have to summarize the results like this:
CREATE TABLE finalresult AS
SELECT id,
sum(ST_Area(the_geom) * val) /
sum(ST_Area(the_geom))) AS meanelev
FROM resulttable
GROUP BY id
ORDER BY id;
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>bounces at postgis.refractions.net] On Behalf Of AJ7
>Sent: 14 mars 2011 13:13
>To: postgis-users at postgis.refractions.net
>Subject: [postgis-users] postgis raster : getting pixel value
>Hi,
>Is it possible to get the pixel value(s) out of the raster image once its
>been exported to postgis raster?
>Basically what I want to do is find the pixel values for all the pixels that
>intersect with a different polygon.
>Not sure if ST_value will help do that.
>tahnks
>View this message in context: http://old.nabble.com/postgis-raster-%3A-getting-pixel-value-
>tp31146394p31146394.html
>Sent from the PostGIS - User mailing list archive at Nabble.com.
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
