[postgis-users] postgis raster : getting pixel value
AJ7
ackbar at ackadij.com
Tue Mar 15 03:10:32 PDT 2011
Pierre Racine-2 wrote:
> the query look like this:
> CREATE TABLE resulttable AS
> SELECT id,
> (gv).geom AS the_geom,
> (gv).val
> FROM (SELECT id,
> ST_Intersection(rast, the_geom) AS gv
> FROM yourrastertable,
> yourpolygontable
> WHERE ST_Intersects(rast, the_geom)
> ) foo;
Pierre,
I get the following error when I do an intersect:
NOTICE: UnsupportedOperationException: GeometryGraph::add(Geometry *):
unknown geometry type: N4geos4geom12MultiPolygonE
CONTEXT: PL/pgSQL function "_st_intersects" line 28 at assignment
SQL function "st_intersects" statement 1
ERROR: GEOS Intersection() threw an error!
Any idea what could be wrong there? Could it be something wrong with the
postgis raster conversion? When I convert the image to a vector file, all
seems fine there.
View this message in context: http://old.nabble.com/postgis-raster-%3A-getting-pixel-value-tp31146394p31152398.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
