[postgis-users] postgis raster : getting pixel value
Jorge Arévalo
jorge.arevalo at deimos-space.com
Tue Mar 15 03:22:01 PDT 2011
On Tue, Mar 15, 2011 at 11:10 AM, AJ7 <ackbar at ackadij.com> wrote:
> Pierre Racine-2 wrote:
>> the query look like this:
>> CREATE TABLE resulttable AS
>> SELECT id,
>> (gv).geom AS the_geom,
>> (gv).val
>> FROM (SELECT id,
>> ST_Intersection(rast, the_geom) AS gv
>> FROM yourrastertable,
>> yourpolygontable
>> WHERE ST_Intersects(rast, the_geom)
>> ) foo;
> Pierre,
> I get the following error when I do an intersect:
> NOTICE: UnsupportedOperationException: GeometryGraph::add(Geometry *):
> unknown geometry type: N4geos4geom12MultiPolygonE
> CONTEXT: PL/pgSQL function "_st_intersects" line 28 at assignment
> SQL function "st_intersects" statement 1
> ERROR: GEOS Intersection() threw an error!
> Any idea what could be wrong there? Could it be something wrong with the
> postgis raster conversion? When I convert the image to a vector file, all
> seems fine there.
> View this message in context: http://old.nabble.com/postgis-raster-%3A-getting-pixel-value-tp31146394p31152398.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Hello,
This error is probably caused because last PostGIS version from trunk
uses a modern version of GEOS library. Could you update your GEOS
version?
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
