[postgis-users] dissolve attributes in a table (no geometry)
Birgit Laggner birgit.laggner at vti.bund.de
Thu Mar 17 01:50:25 PDT 2011
  Hi Júlio,
you could use DISTINCT ON:
select distinct on (point_id) point_id, line_id, distance from
worktemp.distances2streets order by point_id, distance;
This selects for every point_id the first row of every point_id group.
Since you have ordered by distance too, the shortest distance is always
on top of the list and will therefore be selected.
Regards,
Birgit.
On 16.03.2011 12:54, Júlio Almeida wrote:
> Hello,
> I have a table with point_id, line_id, and distance (from point to line).
> I need to create a new table with the record for the shortest distance for
> each point.
> I have tried:
> select point_id,
> line_id,
> min(distance)
> from worktemp.distances2streets group by point_id;
> but i get the message:
> ERROR:  column "distances2streets.line_id" must appear in the GROUP BY
> clause or be used in an aggregate function
> LINE 2: line_id,
> ********** Erro **********
> clause
> Estado de SQL:42803
> Carácter:18
> Any suggestion?
> Thanks
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110317/e2225c57/attachment.html>
