[postgis-users] dissolve attributes in a table (no geometry)
Júlio Almeida
julio.augusto.almeida at gmail.com
Thu Mar 17 10:51:12 PDT 2011
Thanks a lot Birgit, works just fine.
Regards
Julio Almeida
On Thu, Mar 17, 2011 at 8:50 AM, Birgit Laggner
<birgit.laggner at vti.bund.de>wrote:
> Hi Júlio,
> you could use DISTINCT ON:
> select distinct on (point_id) point_id, line_id, distance from
> worktemp.distances2streets order by point_id, distance;
> This selects for every point_id the first row of every point_id group.
> Since you have ordered by distance too, the shortest distance is always on
> top of the list and will therefore be selected.
> Regards,
> Birgit.
> On 16.03.2011 12:54, Júlio Almeida wrote:
> Hello,
> I have a table with point_id, line_id, and distance (from point to line).
> I need to create a new table with the record for the shortest distance for
> each point.
> I have tried:
> select point_id,
> line_id,
> min(distance)
> from worktemp.distances2streets group by point_id;
> but i get the message:
> ERROR: column "distances2streets.line_id" must appear in the GROUP BY
> clause or be used in an aggregate function
> LINE 2: line_id,
> ********** Erro **********
> clause
> Estado de SQL:42803
> Carácter:18
> Any suggestion?
> Thanks
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110317/a30200f8/attachment.html>
