[postgis-users] postgis 2 installation failing
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Mar 18 02:52:38 PDT 2011
On 15/03/11 14:07, AJ7 wrote:
> Hi,
> I downloaded the source for Postgis2.0, and when trying to install (make) it
> on snow leopard , its failing and this is the error:
> collect2: ld returned 1 exit status
> lipo: can't open input file:
> /var/folders/Uz/Uz-J-wY0HAW5jjSNhXRDNk+++TI/-Tmp-//ccjtYJzA.out (No such
> file or directory)
> make[1]: *** [postgis-2.0.so] Error 1
> make: *** [all] Error 1
> - The ./configure worked fine. any ideas?
> thanks
That looks strange. I've only seen similar symptoms before when I've run
out of memory/disk space when attempting a build.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
