[postgis-users] postgis 2 installation failing
AJ7 ackbar at ackadij.com
Fri Mar 18 04:38:36 PDT 2011
Mark Cave-Ayland-3 wrote:
> That looks strange. I've only seen similar symptoms before when I've run
> out of memory/disk space when attempting a build.
> ATB,
> Mark.
hi mark, I have got more than enough disk space, and i have tried rebooting
my machine several time in case it was out of memory....but still get the
problem.
Does postgis2.0 have dependencies on particular library versions? like geos?
View this message in context: http://old.nabble.com/postgis-2-installation-failing-tp31153068p31180402.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
