[postgis-users] postgis 2 installation failing
William Kyngesburye woklist at kyngchaos.com
Fri Mar 18 06:34:51 PDT 2011
How are you configuring PostGIS?  I have build instructions on my site (use the framework alternate at the bottom of the postgis page).  It's more than a simple configure, you need to set some environment variables.
This sort of error often happens when there was another error earlier in compilation that wasn't enough to stop compilation then.
On Mar 18, 2011, at 6:38 AM, AJ7 wrote:
> Mark Cave-Ayland-3 wrote:
>> That looks strange. I've only seen similar symptoms before when I've run
>> out of memory/disk space when attempting a build.
>> ATB,
>> Mark.
> hi mark, I have got more than enough disk space, and i have tried rebooting
> my machine several time in case it was out of memory....but still get the
> problem.
> Does postgis2.0 have dependencies on particular library versions? like geos?
> View this message in context: http://old.nabble.com/postgis-2-installation-failing-tp31153068p31180402.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
