[postgis-users] postgis 2 installation failing
    William Kyngesburye
    woklist at kyngchaos.com
    Fri Mar 18 07:26:59 PDT 2011
On Mar 18, 2011, at 9:13 AM, William Kyngesburye wrote:
> On Mar 18, 2011, at 8:34 AM, William Kyngesburye wrote:
>> How are you configuring PostGIS?  I have build instructions on my site (use the framework alternate at the bottom of the postgis page).  It's more than a simple configure, you need to set some environment variables.
> Of course, those instructions are for 1.5.  For 2.0:
> export MACOSX_DEPLOYMENT_TARGET=10.6
> export CFLAGS="-Os -arch i386 -arch x86_64"
> export PG_CPPFLAGS="-arch i386 -arch x86_64"
> export SHLIB_LINK="-arch i386 -arch x86_64"
> export LDFLAGS="-arch i386 -arch x86_64"
> ./configure --with-pgconfig=/usr/local/pgsql-9.0/bin/pg_config \
> --with-geosconfig=/Library/Frameworks/GEOS.framework/Programs/geos-config \
> --with-projdir=/Library/Frameworks/PROJ.framework/unix \
> --with-raster --with-topology \
> --with-gdalconfig=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> So, lwgeom builds, but I get the error in shp2pgsql-core.c.  The other shp2pgsql sources compile.  It looks like shp2pgsql-core.c compile doesn't get any -I flags so it can't find my libintl header.
Got - try configuring without NLS:
--with-raster --with-topology --disable-nls \
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
