[postgis-users] postgis 2 installation failing
Ackbar Joolia ackbar at ackadij.com
Fri Mar 18 08:54:42 PDT 2011
Hi William,
As you have said, its failing when I set the CFLAGS.
Sorry I meant to say configure works without the CFLAGS="-Os -arch i386
-arch x86_64", but the make fails.
using the gettext didn't make any difference, I still get the error:
checking for xmlInitParser in -lxml2... no
configure: error: could not find libxml2
(btw, I want to get postgis2.0 installed on the snow leopard 10.6 to use the
postgis raster)
On 18 March 2011 15:10, William Kyngesburye <woklist at kyngchaos.com> wrote:
> > This is strange, when I use the following command
> > ./configure --with-pgconfig=/usr/local/pgsql-9.0/bin/pg_config \
> > --with-geosconfig=/Library/Frameworks/GEOS.framework/Programs/geos-config
> > --with-projdir=/Library/Frameworks/PROJ.framework/unix \
> > --with-raster --with-topology --disable-nls \
> > --with-gdalconfig=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> > without setting the environment variables (the exports),
> Without the *FLAGS, you just get a single-arch build, most likely x86_64 on
> OSX 10.6.  And most builds default to using the debug flag, so I always set
> CFLAGS to -Os.
> The deployment target is just something I do and is not critical.
> > the compile works (although the make is still failing),
> Well, make IS the compile.  Or do you mean the configure works?
> Maybe --disable-nls isn't all that's needed - what I actually did was
> configure for my custom gettext, and assumed that disabling it would work.
>  I suppose since you have Macports you could try using that - instead of
> --disable-nls, try:
> --with-gettext=/opt/local
> > but when I use the environment variables, the ./configure fails with this
> error:
> > I don't know why it can't find it, when its /opt/local/bin/xml2-config
> here.
> It should find it from the system, no need for macports.  Though it's
> possible Macports is confusing the configuration.  Generally, I don't think
> Macports is automatically checked, it depends on the software.  Straight Gnu
> configure won't, but some software checks for it.
> > On 18 March 2011 14:26, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > On Mar 18, 2011, at 9:13 AM, William Kyngesburye wrote:
> > > On Mar 18, 2011, at 8:34 AM, William Kyngesburye wrote:
> > >> How are you configuring PostGIS?  I have build instructions on my site
> (use the framework alternate at the bottom of the postgis page).  It's more
> than a simple configure, you need to set some environment variables.
> > > Of course, those instructions are for 1.5.  For 2.0:
> > > export MACOSX_DEPLOYMENT_TARGET=10.6
> > > export CFLAGS="-Os -arch i386 -arch x86_64"
> > > export PG_CPPFLAGS="-arch i386 -arch x86_64"
> > > export SHLIB_LINK="-arch i386 -arch x86_64"
> > > export LDFLAGS="-arch i386 -arch x86_64"
> --with-geosconfig=/Library/Frameworks/GEOS.framework/Programs/geos-config \
> > > --with-raster --with-topology \
> > > So, lwgeom builds, but I get the error in shp2pgsql-core.c.  The other
> shp2pgsql sources compile.  It looks like shp2pgsql-core.c compile doesn't
> get any -I flags so it can't find my libintl header.
> > Got - try configuring without NLS:
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to possess
> - money to purchase the effeminate pleasures of weaklings.  And yet withal
> bound down by silly customs that make them slaves to their unhappy lot while
> firm in the belief that they be the lords of creation enjoying the only real
> pleasures of existence....
> > - the wisdom of Tarzan
> "The beast is actively interested only in now, and, as it is always now and
> always shall be, there is an eternity of time for the accomplishment of
> objects."
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110318/4ec7f75f/attachment.html>
