[postgis-users] Tiger Geocoder error when street name contains nameof state
Paragon Corporation lr at pcorp.us
Sat Mar 19 22:30:47 PDT 2011
Dan,
This is not a known bug to my knowledge.  Can you put in a ticket for this
and I'll check it out.
http://trac.osgeo.org/postgis/newticket
Catalog it under component : tiger geocoder / PostGIS 2.0.0
If you wanted to pass individual elements -- create an object  of type
norm_addy and set the individual elements.
Something like this:
SELECT ROW(2450,'N','COLORADO', 'ST', '', '', 'PHILADELPHIA', 'PA', '19132',
false)::norm_addy
Then use the geocode version that takes an already normalized address
http://www.postgis.org/documentation/manual-svn/Geocode.html  (the second
function)
So - check and see if the below works
SELECT geocode(ROW(2450,'N','COLORADO', 'ST', '', '', 'PHILADELPHIA', 'PA',
'19132', false)::norm_addy);
Thanks,
Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Daniel
Ball
Sent: Saturday, March 19, 2011 10:03 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Tiger Geocoder error when street name contains
nameof state
Hi all,
I've been toying with the Tiger Geocoder and have run into a minor problem.
I can successfully geocode most street addresses:
SELECT
    g.rating,
    ST_X(g.geomout) as lon,
    ST_Y(g.geomout) as lat
  FROM GEOCODE('1124 BERKSHIRE AVE, PITTSBURGH, PA 15226') as g;
 rating |        lon        |       lat
      0 | -80.0163301048089 | 40.3898836658447
However, if I try an address with a street name that includes the name of a
state:
SELECT
    g.rating,
  FROM GEOCODE('2450 N COLORADO ST, PHILADELPHIA, PA, 19132') as g;
ERROR:  query string argument of EXECUTE is null
CONTEXT:  PL/pgSQL function "location_extract" line 54 at EXECUTE statement
PL/pgSQL function "normalize_address" line 142 at assignment PL/pgSQL
function "geocode" line 10 at assignment
Note that misspelling the name of the street fixes the problem:
SELECT
    g.rating,
  FROM GEOCODE('2450 N COLORADA ST, PHILADELPHIA, PA, 19132') as g;
 rating |        lon        |       lat
     10 | -75.1607586938776 | 39.9908191428571
Haven't quite worked out the details of the address parser, but I'm assuming
it's matching the state name in the street and throwing off the what it's
passing to the geocoder.
Is this a known bug or something I'm doing wrong? Is it possible to pass
individual elements of the address to the coder explicitly (e.g.,
street="2450 N Colorado ST", city="Philadelphia", state="PA", zip="19132")?
Thanks in advance for your help!
Dan
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
