[postgis-users] Problems with ST_Within in an island of amultipolygon
Paragon Corporation
lr at pcorp.us
Fri Mar 25 10:56:22 PDT 2011
Interesting -- I can confirm too. When I do a ST_Dwithin check things
behave right.
select gid, ST_NPoints(the_geom),
ST_Distance(the_geom,ST_GeomFromText('POINT (-115.04252 36.05137)', -1)) As
dist ,
ST_DWithin(ST_GeomFromText('POINT (-115.04252 36.05137)', -1),
the_geom,0.0000001) from foo_reload
gid | st_npoints | dist | st_dwithin
1 | 111 | 0.149589748004329 | f
2 | 342 | 0.00350800000001072 | f
3 | 2916 | 0 | t
I'm guessing it's something amiss with the prepared geometry logic that its
somehow using the hash key from the previous geometry.
Paul any thoughts?
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Larry
Reeder
Sent: Friday, March 25, 2011 12:41 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Problems with ST_Within in an island of
amultipolygon
FYI, I verified I can reproduce this behavior in PostGIS 1.5.2:
# SELECT postgis_full_version();
POSTGIS="1.5.2" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.7" USE_STATS
On Fri, Mar 25, 2011 at 10:11 AM, Larry Reeder <lnreeder at gmail.com> wrote:
> Thanks for the response, Sandro. I've posted a test case on Dropbox
> at http://dl.dropbox.com/u/14591732/foo_reload.sql. This SQL script
> will create a table called "foo_reload" with three features. Here's
> my sample session:
> # \i /tmp/foo_reload.sql
> [load statements removed]
> # select gid, ST_IsValid(the_geom) from foo_reload;
> gid | st_isvalid
> 1 | t
> 2 | t
> 3 | t
> (3 rows)
> So, all 3 features are valid. Good.
> # select ST_Within(ST_GeomFromText('POINT (-115.04252 36.05137)',
> -1), the_geom) from foo_reload where gid = 3;
> st_within
> t
> (1 row)
> Feature #3 contains my test point. Good.
> # SELECT gid from foo_reload where ST_Within(ST_GeomFromText('POINT
> (-115.04252 36.05137)', -1), the_geom);
> gid
> (0 rows)
> No features contain my test point. What????
> # delete from foo_reload where gid = 2; DELETE 1
> Deleted feature #2 from my layer. This is the "water" that surrounds
> my multipolygon "island".
> gid
> 3
> (1 row)
> Now PostGIS tells me that feature #3 contains the point. What??
> Can anyone else reproduce my problem?
> Thanks.............. Larry
> On Wed, Mar 23, 2011 at 3:23 PM, Sandro Santilli <strk at keybit.net> wrote:
>> On Tue, Mar 22, 2011 at 07:17:26AM -0600, Larry Reeder wrote:
>>> Anybody have any ideas on this one? Do you think I should post it
>>> to the developer list?
>> You might post a testcase, the smallest possible.
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://strk.keybit.net/services.html
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
