[postgis-users] "Linux" geocoder script ?
fork
forkandwait at gmail.com
Fri Mar 25 16:31:23 PDT 2011
fork <forkandwait <at> gmail.com> writes:
> Paragon Corporation <lr <at> pcorp.us> writes:
> > One of these days hopefully soon, I'll dust off my OpenSUSE VM and build
> > PostGIS 2.0 and test Tiger geocoder on it.
If anyone is interested, I have been working on an alternative script to import
Tiger, based on the output from the function that generates a script. Its a
"gist" on github.
I have only tested it piecemeal, and it is currently bombing at "## create
address data, one per county" near the bottom (I think because the tiger parent
addr table doesn't match the table generated by shp2pgsql.
I will probably also add code to set up an optional basic geocoder install at
the top.
No warranty, blah, blah, blah.
The idea is that you just change a few parameters at the top and then run it for
your state. It would be *far* easier to write code to SQL to generate a bunch
of "X=Y\n" lines than what it does now.
I also prettified it and wrapped in BEGIN/END blocks whenever I thought possible.
Voila: https://gist.github.com/885803
And if anyone has ideas or patches, please send them (it would be really cool to
figure out a "pull request" on github,...)
