[postgis-users] MULTILINESTRING to MULTIPOLYGON
Javier Perez
javi.peisaco at gmail.com
Wed Mar 30 02:43:45 PDT 2011
Hi Birgit!
In the end I made it programaticaly, using a gvsig class:
GeometryUtilities.closeLine().
If there was a siple solution aplying only one or two operations, it would
be reasonable using postgis. But in my case the geometry was in memory as a
multilinestring, and wanted to store it as a multipolygon, and this solution
is more elegant and easy, always in my case.
Anyway I'll keep your code for further needs, and thank you for your
attention.
Regards,
Javier
2011/3/30 Birgit Laggner <birgit.laggner at vti.bund.de>
> Hi Javier,
> you could add the missing end point (and then try again with ST_BuildArea()
> etc.). Here a more or less suiting example of the PostGIS manual for
> ST_AddPoint():
> UPDATE sometable
> SET the_geom = ST_AddPoint(the_geom, ST_StartPoint(the_geom))
> FROM sometable
> WHERE ST_IsClosed(the_geom) = false;
> With a MultiLineString, this might be a bit more complicated because you
> have to find out first, is your multilinestring resulting in a polygon or a
> multipolygon? If all linestrings form one polygon, you have to select the
> start point of the first linestring as end point of the last linestring. If
> the result is a multipolygon, you have to find out which of the rings is not
> closed, first. As I see from your first e-mail, you are expecting the
> geometry to become a multipolygon, so (assuming every linestring is
> representing a polygon within the multipolygon, otherwise it might be a
> solution to union the linestrings first) maybe the sql code could look like
> this:
> UPDATE sometable a
> SET the_geom = sel.geom FROM
> (SELECT b1.gid, ST_Collect(b1.geom) AS geom --put together all linestrings to one multilinestring again
> FROM
> (SELECT b.gid, ST_AddPoint(b.geom, ST_StartPoint(b.geom)) --add an end point on the position of the start point for each non-closed linestring
> FROM
> (SELECT gid, (st_dump(the_geom)).geom AS geom --separate the linestrings and select the not closed ones
> FROM sometable
> WHERE ST_IsClosed(the_geom)=false) b
> WHERE ST_IsClosed(b.geom) = false
> UNION ALL
> SELECT b.gid, b.geom
> FROM
> (SELECT gid, (st_dump(the_geom)).geom AS geom --separate the linestrings and select the closed ones
> FROM sometable
> WHERE ST_IsClosed(b.geom) = true) b1
> GROUP BY b1.gid) sel
> WHERE ST_IsClosed(a.the_geom)=false AND a.gid=sel.gid;
> I did not test the code, but I hope you get the idea...
> Regards,
> Birgit.
> On 28.03.2011 18:47, Javier Perez wrote:
> Hi,
> I tried *ST_BuildArea*(geometry A); and *ST_BdMPolyFromText*(text WKT,
> integer srid);
> but the output is empty. I think it's becouse this functions may need the
> MULTILINESTRING to be closed and it's not.
> Any suggestion?
> 2011/3/25 Javier Perez <javi.peisaco at gmail.com>
>> Hi Marc-Andre!
>> I think this usefull.
>> Thanks a lot!
>> Regards
>> 2011/3/25 Morin, Marc-André <Marc-Andre.Morin at dfo-mpo.gc.ca>
>>> *Hi,*
>>> *This is the recipe I found in the past to get it done:*
>>> http://postgis.refractions.net/pipermail/postgis-users/2008-May/019901.html
>>> It worked well for me.
>>> Regards,
>>> Marc-André
>>> *De :* postgis-users-bounces at postgis.refractions.net [mailto:
>>> postgis-users-bounces at postgis.refractions.net] *De la part de* Javier
>>> Perez
>>> *Envoyé :* March 25, 2011 7:35 AM
>>> *À :* postgis-users at postgis.refractions.net
>>> *Objet :* [postgis-users] MULTILINESTRING to MULTIPOLYGON
>>> Hi!,
>>> In my app I get a MULTILINESTRING and want to insert it as
>>> MULTIPOLYGON. I think there's an easy way but I did't found, can anyone
>>> bring some light?
>>> Thanks in advance
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110330/03ddcee3/attachment.html>
