[postgis-users] Point as Index
Nicklas Avén
nicklas.aven at jordogskog.no
Wed Mar 30 06:59:22 PDT 2011
Hallo
printing out that many row take a lot of time.
try:
select
count(*)
from
feed_all.common_pos_messages
where
st_contains(ST_GeomFromText('POLYGON((0.00433541700872238
51.6875086022247,1.4450615615687 51.6875086022247,1.4450615615687
51.2018083846302,0.00433541700872238
51.2018083846302,0.00433541700872238 51.6875086022247))', 4326),
pos_point)
to see how much of the time actually is calculations.
/Nicklas
On Wed, 2011-03-30 at 14:40 +0100, Ioannis Anagnostopoulos wrote:
> The precise numbers are as follows:
> Total Rows in the table: 45922415
> if I use:
> select
> pos_lat,
> pos_lon
> from
> where
> pos_point)
> I get back: 4493678 in 4.77 mins
> Doing explain analyze I get:
> "Bitmap Heap Scan on common_pos_messages (cost=82262.99..522647.01
> rows=771600 width=8) (actual time=127735.424..198141.843 rows=4493678
> loops=1)"
> " Recheck Cond:
> ('0103000020E61000000100000005000000D29145A403C2713F0B23294800D84940E04E3ADFF81EF73F0B23294800D84940E04E3ADFF81EF73FCC056EDBD4994940D29145A403C2713FCC056EDBD4994940D29145A403C2713F0B23294800D84940'::geometry && pos_point)"
> " Filter:
> _st_contains('0103000020E61000000100000005000000D29145A403C2713F0B23294800D84940E04E3ADFF81EF73F0B23294800D84940E04E3ADFF81EF73FCC056EDBD4994940D29145A403C2713FCC056EDBD4994940D29145A403C2713F0B23294800D84940'::geometry, pos_point)"
> " -> Bitmap Index Scan on idx_pos (cost=0.00..82070.09 rows=2314801
> width=0) (actual time=127732.000..127732.000 rows=4493679 loops=1)"
> " Index Cond:
> "Total runtime: 199206.428 ms"
> Obviously the times and the rows do not seem to much with the actual
> results. However after creating my own index based on lat/lon values
> (integers) on the same table, executing this:
> select
> pos_lat,
> pos_lon
> from
> where
> pos_lat between 30721085 and 31012505 and
> pos_lon between 2601 and 867037
> I get back 4493680 in 2.8 mins
> "Bitmap Heap Scan on common_pos_messages (cost=161748.26..601144.64
> rows=1686719 width=8) (actual time=10064.427..60738.808 rows=4493680
> loops=1)"
> " Recheck Cond: ((pos_lat >= 30721085) AND (pos_lat <= 31012505) AND
> (pos_lon >= 2601) AND (pos_lon <= 867037))"
> " -> Bitmap Index Scan on idx_lat_lon (cost=0.00..161326.58
> rows=1686719 width=0) (actual time=10061.108..10061.108 rows=4493680
> loops=1)"
> " Index Cond: ((pos_lat >= 30721085) AND (pos_lat <= 31012505)
> AND (pos_lon >= 2601) AND (pos_lon <= 867037))"
> "Total runtime: 61850.720 ms"
> The predictions are still "out" from the actual but the btree index
> seems to behave better.
> Any suggestions? Probably I need to bring up to date my statistics.
> Kind Regards
> Yiannis
> On 30/03/2011 13:30, Sandro Santilli wrote:
> > On Wed, Mar 30, 2011 at 10:58:57AM +0100, Ioannis Anagnostopoulos wrote:
> > > I am involved in a heavy database design initiative where the only kind
> > > of geometries I am dealing with are points. I have recently hit a
> > > 50million rows long table with those points and my default gist index on
> > > the points does not seem to be working very fast (if not at all to be
> > > honest). I have started now thinking that probably for "points" an index
> > > may not be the best option since in a 50million rows long table most of
> > > the points are unique so the index may just duplicate the actual table,
> > > of course I may be wrong and I may just missing a very important part of
> > > the concept.
> > How many points from the 50M set does your tipical query hits ?
> > Does PostgreSQL selectivity estimator make a good guess about that ?
> > Use EXPLAIN ANALYZE <your query here> to see.
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
> postgis-users mailing list
