[postgis-users] Point as Index
Ioannis Anagnostopoulos
ioannis at anatec.com
Wed Mar 30 07:03:36 PDT 2011
No problem :)
Yiannis
On 30/03/2011 15:01, Nicklas Avén wrote:
> Sorry, I was too fast on the keys.
> before I saw the comparasion with your own index
> /Nicklas
> On Wed, 2011-03-30 at 14:40 +0100, Ioannis Anagnostopoulos wrote:
>> The precise numbers are as follows:
>> Total Rows in the table: 45922415
>> if I use:
>> select
>> pos_lat,
>> pos_lon
>> from
>> feed_all.common_pos_messages
>> where
>> st_contains(ST_GeomFromText('POLYGON((0.00433541700872238
>> 51.6875086022247,1.4450615615687 51.6875086022247,1.4450615615687
>> 51.2018083846302,0.00433541700872238
>> 51.2018083846302,0.00433541700872238 51.6875086022247))', 4326),
>> pos_point)
>> I get back: 4493678 in 4.77 mins
>> Doing explain analyze I get:
>> "Bitmap Heap Scan on common_pos_messages (cost=82262.99..522647.01
>> rows=771600 width=8) (actual time=127735.424..198141.843 rows=4493678
>> loops=1)"
>> " Recheck Cond:
>> ('0103000020E61000000100000005000000D29145A403C2713F0B23294800D84940E04E3ADFF81EF73F0B23294800D84940E04E3ADFF81EF73FCC056EDBD4994940D29145A403C2713FCC056EDBD4994940D29145A403C2713F0B23294800D84940'::geometry&& pos_point)"
>> " Filter:
>> _st_contains('0103000020E61000000100000005000000D29145A403C2713F0B23294800D84940E04E3ADFF81EF73F0B23294800D84940E04E3ADFF81EF73FCC056EDBD4994940D29145A403C2713FCC056EDBD4994940D29145A403C2713F0B23294800D84940'::geometry, pos_point)"
>> " -> Bitmap Index Scan on idx_pos (cost=0.00..82070.09 rows=2314801
>> width=0) (actual time=127732.000..127732.000 rows=4493679 loops=1)"
>> " Index Cond:
>> "Total runtime: 199206.428 ms"
>> Obviously the times and the rows do not seem to much with the actual
>> results. However after creating my own index based on lat/lon values
>> (integers) on the same table, executing this:
>> select
>> pos_lat,
>> pos_lon
>> from
>> where
>> pos_lat between 30721085 and 31012505 and
>> pos_lon between 2601 and 867037
>> I get back 4493680 in 2.8 mins
>> "Bitmap Heap Scan on common_pos_messages (cost=161748.26..601144.64
>> rows=1686719 width=8) (actual time=10064.427..60738.808 rows=4493680
>> loops=1)"
>> " Recheck Cond: ((pos_lat>= 30721085) AND (pos_lat<= 31012505) AND
>> (pos_lon>= 2601) AND (pos_lon<= 867037))"
>> " -> Bitmap Index Scan on idx_lat_lon (cost=0.00..161326.58
>> rows=1686719 width=0) (actual time=10061.108..10061.108 rows=4493680
>> loops=1)"
>> " Index Cond: ((pos_lat>= 30721085) AND (pos_lat<= 31012505)
>> AND (pos_lon>= 2601) AND (pos_lon<= 867037))"
>> "Total runtime: 61850.720 ms"
>> The predictions are still "out" from the actual but the btree index
>> seems to behave better.
>> Any suggestions? Probably I need to bring up to date my statistics.
>> Kind Regards
>> Yiannis
>> On 30/03/2011 13:30, Sandro Santilli wrote:
>>> On Wed, Mar 30, 2011 at 10:58:57AM +0100, Ioannis Anagnostopoulos wrote:
>>>> I am involved in a heavy database design initiative where the only kind
>>>> of geometries I am dealing with are points. I have recently hit a
>>>> 50million rows long table with those points and my default gist index on
>>>> the points does not seem to be working very fast (if not at all to be
>>>> honest). I have started now thinking that probably for "points" an index
>>>> may not be the best option since in a 50million rows long table most of
>>>> the points are unique so the index may just duplicate the actual table,
>>>> of course I may be wrong and I may just missing a very important part of
>>>> the concept.
>>> How many points from the 50M set does your tipical query hits ?
>>> Does PostgreSQL selectivity estimator make a good guess about that ?
>>> Use EXPLAIN ANALYZE<your query here> to see.
>>> --strk;
>>> () Free GIS& Flash consultant/developer
>>> /\ http://strk.keybit.net/services.html
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
