[postgis-users] Distance constraints on spatial points
fork forkandwait at gmail.com
Tue May 3 16:18:13 PDT 2011
Sairam Krishnamurthy <kmsram420 <at> gmail.com> writes:
> Thanks. But how do I specify the code to raise an error if the distance is
> not met ?
You probably want to write a PLPGSQL function with a SELECT statement that
returns the min(st_distance(NEW.the_geom, a.the_geom)), and raise an exception
if it is below a certain amount.  You might need to multiply by constants to get
the return value into your prefered units. Then you need to set up a trigger to
call it on an insert.
If you don't know how to write PLPGSQL, you need to learn ;)... or maybe
somebody else can help with example code, but even more or less knowing how to
do it, it would take me an hour to write working code, and I cant spare the time
(tho it would be fun).
Or you need to ask a more specific question after posting the code you have
tried -- that would be best.
