[postgis-users] ST_Intersects
Birgit Laggner birgit.laggner at vti.bund.de
Thu May 5 06:07:00 PDT 2011
Hi Shreyes,
if I understand your question right, it's not much different from what
you asked before. You would select the intersecting geometries of both
tables by asking for st_intersects(a.the_geom,b.the_geom)=true, then
intersect those geometries with st_intersection() and then calculate the
area of the intersection with st_area(). For the identification of the
origin of the resulting geometries, you select the id columns of the
tables plots and parcels, too - so, you would see that plot S01BAT009
does have intersecting geometries with parcels P1, P2 and P3 (in your
example). Here an example for such a query:
select
a.plot_id,
b.parcel_id,
st_area(st_intersection(a.the_geom, b.the_geom)) as the_geom
from
plots a
inner join
parcels b
on a.the_geom && b.the_geom
where st_intersects(a.the_geom, b.the_geom);
I don't know exactly what you mean by redundant tuples - perhaps it
would help, if you would post your query and an example of its result
here too...
Regards,
Birgit.
Am 05.05.2011 14:35, schrieb shreyes shiv:
> Dear all,
> I have two shape files plots and parcels.
> the attributes of the "plots" shape file are
> plot_id
> plot_area
> owner_nm
> the_geom
> the attributes of the "parcels" shape file are
> parcel_id
> parcel_area
> conversion
> the_geom
> when i do the ST_Intersects operation on the shape files it returns a
> table that contains redundant tuples.
> what i want is the area of the newly formed polygons which are formed
> after the intersection as an extra column.
> This image explains my problem.
> The Plot S01BAT009 lying in Parcels P1, P2 and P3, and also occupying
> the area A1, A2 and A3 in the respective parcels. The white lines are
> the parcel boundaries. The black lines are the plot boundaries.
> I want the areas A1, A2 and A3.
> please help.
> shreyes shiv
> email: shivshreyes at gmail.com <mailto:shivshreyes at gmail.com>
> phone: 9557975780
> IIRS(Indian Institute of Remote Sensing)
> No. 4, Kalidas Road, Dehradun-248001, Uttarakhand, India
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110505/2ae70fb3/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110505/2ae70fb3/attachment.jpe>
