[postgis-users] Intersection query problem
Ben Madin lists at remoteinformation.com.au
Tue May 10 20:36:55 PDT 2011
George,
You need to put source.track_cl into the table list for your query...
hint - it is in the table list for your sub-select, but not for the main query, I know some people scorn indenting, but :
SELECT  gid,  name, track_use, st_astext(clipped_geom)
FROM  (
	SELECT  source.track_cl.gid,  source.track_cl.name,  source.track_cl.track_use,
	(ST_Dump(ST_Intersection(
		extents.tiles.the_geom,  source.track_cl.the_geom
	))).geom  As  clipped_geom
	FROM  source.track_cl
	INNER  JOIN  extents.tiles
	ON  ST_Intersects(extents.tiles.the_geom,  source.track_cl.the_geom)
	WHERE extents.tiles.name='BP33'
) As  clipped
WHERE  st_geometrytype(clipped.clipped_geom) = st_geometrytype(source.track_cl.the_geom);
cheers
Ben
On 11/05/2011, at 11:15 AM, George Washington wrote:
> Hi, I have the following query:
> FROM  (SELECT  source.track_cl.gid,  source.track_cl.name,  source.track_cl.track_use,(ST_Dump(ST_Intersection(extents.tiles.the_geom,  source.track_cl.the_geom))).geom  As  clipped_geom
> ON  ST_Intersects(extents.tiles.the_geom,  source.track_cl.the_geom) where extents.tiles.name='BP33' ) As  clipped
> which gives me:
> ERROR:  missing FROM-clause entry for table "track_cl"
> LINE 6: ...metrytype(clipped.clipped_geom) = st_geometrytype(source.tra...
> SQL state: 42P01
> Character: 471
> On the other hand this version of the same query works (only the last line differs):
> ON  ST_Intersects(extents.tiles.the_geom,  source.track_cl.the_geom) where tiles.name='BP33' ) As  clipped
> WHERE  ST_Dimension(clipped.clipped_geom)  >0;
> I cannot figure out what is wrong with the first query.
> Many thanks.
> George
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110511/88b76aea/attachment.html>
