[postgis-users] how to keep geometry_columns in sync with tables and views
G. van Es gves2000 at yahoo.com
Wed May 18 04:38:51 PDT 2011
Hi All,
We have a lot of tables and views updated, or better said, replaced on a daily basis. We have seen that under certain conditions (which are unclear) entries of the geometry_columns table are removed. So a mismatch occurs so now and then resulting in showing either no data or being very slow when an application has to do a table scan to obtain the geometry type.
What I like to have is a procedure which checks all tables and views against the geometry_columns table and makes if necessary the right corrections.
Before inventing the wheel again, does anyone know if this procedure already exist or knows perhaps another/better way to achieve this?
Thanks in advance,
Ge
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110518/2feb5bbd/attachment.html>
