[postgis-users] how to keep geometry_columns in sync with tables and views
Ben Madin
lists at remoteinformation.com.au
Wed May 18 17:50:35 PDT 2011
Ge,
Try
SELECT Populate_Geometry_Columns();
http://postgis.refractions.net/docs/Populate_Geometry_Columns.html
which promises to truncate the geometry columns table first, then rebuild it.
cheers
Ben
On 18/05/2011, at 8:05 PM, G. van Es wrote:
> Hi Edward,
> This will not work because this function doesn't do anything with views. Also stale records aren't removed.
> Ge
> --- On Wed, 5/18/11, Edward Mac Gillavry <emacgillavry at hotmail.com> wrote:
> From: Edward Mac Gillavry <emacgillavry at hotmail.com>
> Subject: Re: [postgis-users] how to keep geometry_columns in sync with tables and views
> To: postgis-users at postgis.refractions.net
> Date: Wednesday, May 18, 2011, 4:57 AM
> Hi Ge,
> You may want to check Probe_Geometry_Columns (http://postgis.refractions.net/docs/Probe_Geometry_Columns.html).
> Kind regards,
> Edward
> Date: Wed, 18 May 2011 04:38:51 -0700
> From: gves2000 at yahoo.com
> Subject: [postgis-users] how to keep geometry_columns in sync with tables and views
> Hi All,
> We have a lot of tables and views updated, or better said, replaced on a daily basis. We have seen that under certain conditions (which are unclear) entries of the geometry_columns table are removed. So a mismatch occurs so now and then resulting in showing either no data or being very slow when an application has to do a table scan to obtain the geometry type.
> What I like to have is a procedure which checks all tables and views against the geometry_columns table and makes if necessary the right corrections.
> Before inventing the wheel again, does anyone know if this procedure already exist or knows perhaps another/better way to achieve this?
> Thanks in advance,
> Ge
> _______________________________________________ postgis-users mailing list postgis-users at postgis.refractions.net http://postgis.refractions.net/mailman/listinfo/postgis-users
> -----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110519/67d18c48/attachment.html>
