[postgis-users] how to keep geometry_columns in sync with tables and views
Ben Madin
lists at remoteinformation.com.au
Wed May 18 18:26:36 PDT 2011
G'day Brent,
I'm forever creating tables as subsets of existing tables so it is a truly useful function, however, I've suffered the same concerns - perhaps it is worth pursuing the name being changed?
I've also never really understood the distinction between the populate_ and the probe_ functions? the probe_ one appears to be a 'lite' version, but it may have some other purpose that I don't understand?
cheers
Ben
On 19/05/2011, at 9:02 AM, pcreso at pcreso.com wrote:
> I foubd this an unfortunately ambiguous name.
> it doesn't populate geometry columns so much as update the geometry_columns table.
> But irrespective of the name, it is nice to have :-)
> Cheers
> Brent Wood
> --- On Thu, 5/19/11, Ben Madin <lists at remoteinformation.com.au> wrote:
> From: Ben Madin <lists at remoteinformation.com.au>
> Subject: Re: [postgis-users] how to keep geometry_columns in sync with tables and views
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Thursday, May 19, 2011, 12:50 PM
> Ge,
> Try
> SELECT Populate_Geometry_Columns();
> http://postgis.refractions.net/docs/Populate_Geometry_Columns.html
> which promises to truncate the geometry columns table first, then rebuild it.
> cheers
> Ben
> On 18/05/2011, at 8:05 PM, G. van Es wrote:
>> Hi Edward,
>> This will not work because this function doesn't do anything with views. Also stale records aren't removed.
>> Ge
>> --- On Wed, 5/18/11, Edward Mac Gillavry <emacgillavry at hotmail.com> wrote:
>> From: Edward Mac Gillavry <emacgillavry at hotmail.com>
>> To: postgis-users at postgis.refractions.net
>> Date: Wednesday, May 18, 2011, 4:57 AM
>> Hi Ge,
>> You may want to check Probe_Geometry_Columns (http://postgis.refractions.net/docs/Probe_Geometry_Columns.html).
>> Kind regards,
>> Edward
>> Date: Wed, 18 May 2011 04:38:51 -0700
>> From: gves2000 at yahoo.com
>> Subject: [postgis-users] how to keep geometry_columns in sync with tables and views
>> Hi All,
>> We have a lot of tables and views updated, or better said, replaced on a daily basis. We have seen that under certain conditions (which are unclear) entries of the geometry_columns table are removed. So a mismatch occurs so now and then resulting in showing either no data or being very slow when an application has to do a table scan to obtain the geometry type.
>> What I like to have is a procedure which checks all tables and views against the geometry_columns table and makes if necessary the right corrections.
>> Before inventing the wheel again, does anyone know if this procedure already exist or knows perhaps another/better way to achieve this?
>> Thanks in advance,
>> Ge
>> _______________________________________________ postgis-users mailing list postgis-users at postgis.refractions.net http://postgis.refractions.net/mailman/listinfo/postgis-users
>> -----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110519/b740c788/attachment.html>
