[postgis-users] Create View problem
Micha Silver micha at arava.co.il
Fri May 20 02:51:04 PDT 2011
On 05/19/2011 10:36 PM, Clay, Bruce wrote:
> This is probably a question for the QGis folks but I wanted to check
> here first where ther is likely a larger audience.
> I create several spatial tables using PostGis and all are visible in
> QGis on their own.
> When I create a view in PostGis that reaches into a variety of tables
> I see the name of the view in QGis but the type is "Waiting" and I get
> an error indicating that QGis can not load the data because it is
> "unable to determine srid and column shape in <view name>" then it
> shows an error <view name>(shape) sql is an invalid layer.
You probably need to create an entry in the geometry_columns table for
this new view. Something like:
INSERT INTO geometry_columns  \
(f_table_catalog,f_table_schema,f_table_name,f_geometry_column,srid,type,coord_dimension)
          VALUES (....);
or even better, use the PostGIS function addgeometrycolumn()
> The SQL is used to create the view follows:
> CREATE OR REPLACE VIEW mission_data.S1_objects AS
>     select M1.object_name, M2.center_lat, m2.center_lon, M2.scene_id,
> M2.OID,
>     ST_Transform(M2.shape,4326) as shape  from
> mission_data.mission_info M1
>     join mission_data.objects M2 ON  M1.object_name = M2.object_name
>    where M1.mission_name = 'E3 Scenario 1' and M1.list_title = 'Object
> List';
> and I alos tried a simpler query
> CREATE VIEW mission_data.S1_test AS
>     SELECT OID, ST_Transform(shape,4326) As shape, object_name
>     FROM mission_data.objects;
> but they both gave the same errors
> I did search the QGis forum web site but did not find anything clues
> or reported issues
> Bruce
> This mail was received via Mail-SeCure System.
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110520/d96f2b1d/attachment.html>
