[postgis-users] Create View problem
Clay, Bruce bclay at ball.com
Thu May 19 12:36:15 PDT 2011
This is probably a question for the QGis folks but I wanted to check here first where ther is likely a larger audience.
I create several spatial tables using PostGis and all are visible in QGis on their own.
When I create a view in PostGis that reaches into a variety of tables I see the name of the view in QGis but the type is "Waiting" and I get an error indicating that QGis can not load the data because it is "unable to determine srid and column shape in <view name>" then it shows an error <view name>(shape) sql is an invalid layer.
The SQL is used to create the view follows:
CREATE OR REPLACE VIEW mission_data.S1_objects AS
    select M1.object_name, M2.center_lat, m2.center_lon, M2.scene_id, M2.OID,
    ST_Transform(M2.shape,4326) as shape  from mission_data.mission_info M1
    join mission_data.objects M2 ON  M1.object_name = M2.object_name
   where M1.mission_name = 'E3 Scenario 1' and M1.list_title = 'Object List';
and I alos tried a simpler query
CREATE VIEW mission_data.S1_test AS
    SELECT OID, ST_Transform(shape,4326) As shape, object_name
    FROM mission_data.objects;
but they both gave the same errors
I did search the QGis forum web site but did not find anything clues or reported issues
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110519/84e29119/attachment.html>
