[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Magnus Hagander
magnus at hagander.net
Thu May 26 07:16:59 PDT 2011
On Thu, May 26, 2011 at 16:15, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, May 26, 2011 at 04:09:27PM +0200, Magnus Hagander wrote:
>> Hi!
>> Yup, it does appear to solve the problem for at least my limited test
>> case. I now get:
>> ERROR: Infinite coordinate value found in geometry.
>> CONTEXT: SQL function "st_intersects" statement 1
>> as expected.
>> Glad to see you found a better place :-)
> Could you please also try ST_IsValid, ST_IsValidReason and
> ST_IsValidDetail against the table containing the offensive
> geometry ?
It's not actually in a table, the offensive geometry was generated by
the app as the other side. Tha tmakes it even easier to check - both
cases return:
Magnus Hagander
Me: http://www.hagander.net/
Work: http://www.redpill-linpro.com/
