[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Sandro Santilli
strk at keybit.net
Thu May 26 07:20:04 PDT 2011
On Thu, May 26, 2011 at 04:16:59PM +0200, Magnus Hagander wrote:
> On Thu, May 26, 2011 at 16:15, Sandro Santilli <strk at keybit.net> wrote:
> > On Thu, May 26, 2011 at 04:09:27PM +0200, Magnus Hagander wrote:
> >> Hi!
> >> Yup, it does appear to solve the problem for at least my limited test
> >> case. I now get:
> >> ERROR: Infinite coordinate value found in geometry.
> >> CONTEXT: SQL function "st_intersects" statement 1
> >> as expected.
> >> Glad to see you found a better place :-)
> > Could you please also try ST_IsValid, ST_IsValidReason and
> > ST_IsValidDetail against the table containing the offensive
> > geometry ?
> It's not actually in a table, the offensive geometry was generated by
> the app as the other side. Tha tmakes it even easier to check - both
> cases return:
My point is that ST_IsValid and friends should return validity information,
not throw an exception. By throwing an exception you don't get any other
result, so can't check the validity of multiple geometries at once.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
