[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Magnus Hagander
magnus at hagander.net
Thu May 26 07:21:19 PDT 2011
On Thu, May 26, 2011 at 16:20, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, May 26, 2011 at 04:16:59PM +0200, Magnus Hagander wrote:
>> On Thu, May 26, 2011 at 16:15, Sandro Santilli <strk at keybit.net> wrote:
>> > On Thu, May 26, 2011 at 04:09:27PM +0200, Magnus Hagander wrote:
>> >> Hi!
>> >> Yup, it does appear to solve the problem for at least my limited test
>> >> case. I now get:
>> >> ERROR: Infinite coordinate value found in geometry.
>> >> CONTEXT: SQL function "st_intersects" statement 1
>> >> as expected.
>> >> Glad to see you found a better place :-)
>> > Could you please also try ST_IsValid, ST_IsValidReason and
>> > ST_IsValidDetail against the table containing the offensive
>> > geometry ?
>> It's not actually in a table, the offensive geometry was generated by
>> the app as the other side. Tha tmakes it even easier to check - both
>> cases return:
> My point is that ST_IsValid and friends should return validity information,
> not throw an exception. By throwing an exception you don't get any other
> result, so can't check the validity of multiple geometries at once.
In that case, the patch is wrong, because it does return an exception.
Magnus Hagander
Me: http://www.hagander.net/
Work: http://www.redpill-linpro.com/
