[postgis-users] New to PostGIS - Simple Question
Paul Ramsey
pramsey at opengeo.org
Thu May 26 11:40:26 PDT 2011
If you have byte-level chops then the most efficient call would be to
ask for ST_AsBinary(geom) and then handle the well-known-binary byte
array on your end. There's some WKB example code in the source repo,
and also in the MapServer PostGIS connector. But it's a pretty easy
format.
P.
On Thu, May 26, 2011 at 11:30 AM, SixDegrees <paulcarlisle at comcast.net> wrote:
> I'm quite new to GIS in general and PostGIS/Postgres in particular. I have to
> write a C/C++ routine to dredge values out of an existing PostGIS-enabled
> database. For the most part, this seems straightforward, but I can't figure
> out how to access the members of types stored as points.
> I'm aware of the ST_X() and ST_Y() SQL functions, but it using these seems
> to require two queries. Is it possible to extract the point type into a
> C/C++ struct/class with one call to the DB and process the results, or do I
> have to make two calls for each point? I can't seem to find a PostGIS API;
> does such a thing exist?
> A short example would be much appreciated, if possible.
> Thank you.
> View this message in context: http://old.nabble.com/New-to-PostGIS---Simple-Question-tp31710695p31710695.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
