[postgis-users] polygon of sphere
pcreso at pcreso.com
Thu May 26 13:25:01 PDT 2011
Hi Mike,
Look at "case" in your SQL, might meet your needs & if the ST_contains()/ST_covers() function reuslt is cached in a select statement, which I think it is now, will be reasonably effective.
http://www.postgresql.org/docs/9.0/interactive/plpgsql-control-structures.html
select case when ST_contains(poly, point) then point_name
else 'sorry, nothing matches' end as my_name,
case when ST_contains(poly, point) then point_desc
else 'there is no description' end as my_desc,
HTH,
Brent Wood
--- On Fri, 5/27/11, Michael Welter <mike at introspect.com> wrote:
Subject: Re: [postgis-users] polygon of sphere
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Friday, May 27, 2011, 7:16 AM
Thanks, Paul,
I have a database of country borders. If the point lies within a particular border then the query will return country-specific information. If the point doesn't lie within a border then I would like to return some default information.
Mike
On May 26, 2011, at 12:42 PM, Paul Ramsey wrote:
> Nope, there isn't. In fact, such a thing will give us the shakes as
> our code for determining in/out status of an object depends on first
> being able to generate one point that is definitively outside the
> containing area. Maybe there is some other way to skin your cat, what
> is the higher level problem you are trying to solve?
> P.
> On Thu, May 26, 2011 at 11:05 AM, Michael Welter <mike at introspect.com> wrote:
>> Hello,
>> Using type GEOGRAPHY, is there a polygon such that ST_COVERS(Polygon,Point) returns true for every point? Something like -180˚ to +180˚ longitude and -90˚ to +90˚ latitude?
>> Thanks,
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110526/a200c7b0/attachment.html>
