[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Sandro Santilli
strk at keybit.net
Fri May 27 12:07:50 PDT 2011
On Fri, May 27, 2011 at 09:28:57AM -0700, Paul Ramsey wrote:
> I'm finding it difficult to have the regression test and also the
> NOTICE in isvalid and also have the differential behaviour for
> different versions of GEOS. One is going to have to go. I can't
> ensure the "reason" I provide in my short circuit to match the reason
> GEOS is going to give.
What you can do is _not_ using tickets.sql but a dedicated file, maybe
bugXXX.sql and bugXXX_pre_geos33.sql, and switch between the two from
the Makefile.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
