[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Magnus Hagander magnus at hagander.net
Tue May 31 05:06:04 PDT 2011
On Fri, May 27, 2011 at 21:07, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, May 27, 2011 at 09:28:57AM -0700, Paul Ramsey wrote:
>> I'm finding it difficult to have the regression test and also the
>> NOTICE in isvalid and also have the differential behaviour for
>> different versions of GEOS. One is going to have to go.  I can't
>> ensure the "reason" I provide in my short circuit to match the reason
>> GEOS is going to give.
> What you can do is _not_ using tickets.sql but a dedicated file, maybe
> bugXXX.sql and bugXXX_pre_geos33.sql, and switch between the two from
> the Makefile.
So to be clear on this for someone who's not following the svn repo -
has a fix for this been applied now?
 Magnus Hagander
 Me: http://www.hagander.net/
 Work: http://www.redpill-linpro.com/
