[postgis-users] Fw: re: Geocoder (from extras)
Paragon Corporation
lr at pcorp.us
Sat May 28 14:24:31 PDT 2011
Mikal,
Can you send me the change you made and the indexes you added. When adding
some more data, I realized I had hardcoded an index for our local state (MA)
and I know without that index that that particular query does run pretty
slow. So just wondering if its along the same lines.
I've also fixed I think all the issues with running the loader on Unix/Linux
-- well at least I was able to get it to run on my CentOS. Thanks to all
who contributed input to that. I took bits and pieces from many people's
comments but couldn't apply a full diff from anyones since I had already
changed the code too much to safely apply any of those patches.
How many states do you have loaded BTW? I just have CA loaded on my CentOS
-- which is an 8GB/8 core cloud server. I'm getting around 38ms - 450ms per
test, but I have yet to load the other states.
It also seems to cache very well so that if I geocode an address on the same
street (not necessarily same address), the first call might take 450ms and
the second 38ms. I suspect this might be because I also marked a good chunk
of the functions STABLE or IMMUTABLE.
Thanks,
Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mikal
Laster
Sent: Friday, May 27, 2011 8:18 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Fw: re: Geocoder (from extras)
--- On Fri, 5/27/11, Mikal Laster <orcltek at yahoo.com> wrote:
Subject: re:[postgis-users] Geocoder (from extras)
Date: Friday, May 27, 2011, 7:22 AM
in response to
http://postgis.refractions.net/pipermail/postgis-users/2011-May/029566.html.
After creating some indexes and rewriting geocode_address. I was able to get
geocode to run in 483-523 ms for "5775 Perimeter Dr Dublin, Ohio". This used
to take 1700-2000 ms for me. I'm removing the main inner qui
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110528/d55c4d81/attachment.html>
