[postgis-users] Geocoder 2010, Pg 9, PostGIS 1.5
maplabs at light42.com
Sat May 28 23:28:52 PDT 2011
I tried hooking up the Geocoder for TIGER 2010 as found in postgis_trunk
but it is failing.. First try was using PostGIS 2.0 trunk, after
problems next was
with PostGIS 1.5.. both with Postgresql 9.0 under linux
It seems if I add the schema tiger_data to search_path
then run create_geocode.sql again manually, it gets a little
further.. but still, I end up with a database that looks like this:
List of relations
Schema | Name | Type | Owner |
Size | Description
public | geography_columns | view | dbb | 0 bytes |
public | geometry_columns | table | dbb | 0 bytes |
public | spatial_ref_sys | table | dbb | 0 bytes |
tiger | addr | table | dbb | 0
bytes |
tiger | addr_gid_seq | sequence | dbb | 8192 bytes |
tiger | county | table | dbb | 0
bytes |
tiger | county_gid_seq | sequence | dbb | 8192 bytes |
tiger | county_lookup | table | dbb | 0 bytes |
tiger | countysub_lookup | table | dbb | 0 bytes |
tiger | cousub | table | dbb | 0
bytes |
tiger | cousub_gid_seq | sequence | dbb | 8192 bytes |
tiger | direction_lookup | table | dbb | 8192 bytes |
tiger | edges | table | dbb | 0
bytes |
tiger | edges_gid_seq | sequence | dbb | 8192 bytes |
tiger | faces | table | dbb | 0
bytes |
tiger | faces_gid_seq | sequence | dbb | 8192 bytes |
tiger | featnames | table | dbb | 0 bytes
tiger | featnames_gid_seq | sequence | dbb | 8192 bytes |
tiger | loader_lookuptables | table | dbb | 16 kB |
tiger | loader_platform | table | dbb | 8192 bytes |
tiger | loader_variables | table | dbb | 8192 bytes |
tiger | place | table | dbb | 0
bytes |
tiger | place_gid_seq | sequence | dbb | 8192 bytes |
tiger | place_lookup | table | dbb | 0 bytes
tiger | secondary_unit_lookup | table | dbb | 8192 bytes |
tiger | state | table | dbb | 0
bytes |
tiger | state_gid_seq | sequence | dbb | 8192 bytes |
tiger | state_lookup | table | dbb | 8192 bytes |
bytes |
bytes |
bytes |
bytes |
bytes |
tiger | street_type_lookup | table | dbb | 24 kB |
tiger | zcta500 | table | dbb | 0
bytes |
tiger | zcta500_gid_seq | sequence | dbb | 8192 bytes |
tiger | zip_lookup | table | dbb | 0 bytes
tiger | zip_lookup_all | table | dbb | 0 bytes |
tiger | zip_lookup_base | table | dbb | 0 bytes |
tiger | zip_state | table | dbb | 0 bytes
tiger | zip_state_loc | table | dbb | 0 bytes |
