[postgis-users] Hausdorf
Stephen V. Mather svm at clevelandmetroparks.com
Tue Nov 1 10:39:24 PDT 2011
Yup, that seems to be it.  Just removed GEOS 3.0.0
Thanks!
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
From: pramsey at cleverelephant.ca [mailto:pramsey at cleverelephant.ca] On Behalf
Of Paul Ramsey
Sent: Tuesday, November 01, 2011 12:54 PM
To: svm at clevelandmetroparks.com; PostGIS Users Discussion
Subject: Re: [postgis-users] Hausdorf
The problem is that you have built against a higher GEOS than you have
installed on your system. Well, actually you probably have two versions
installed in your system, it's just that PostGIS is finding the lower one at
runtime. Run 'ldd' on postgis.so to see what libgeos is being picked up and
then get rid of it so that the newer one takes priority.
P.
On Tue, Nov 1, 2011 at 9:36 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
The latest PostGIS requires a later GEOS (actually, the build should be
avoiding this symbol for older versions of GEOS, what version of GEOS do you
have?) so get the latest GEOS too.
P.
On Tue, Nov 1, 2011 at 7:20 AM, Stephen V. Mather
<svm at clevelandmetroparks.com> wrote:
Hi All,
                In over my head. .  Got PostGIS 2.0 compiled and installed
with 9.1 (after having some success with it with 8.4) and ran into the
following error when I try to apply postgis.sql to my database:
postgres at postgis:/usr/share/postgresql/contrib/postgis-2.0$  psql -d test -f
postgis.sql
SET
BEGIN
psql:postgis.sql:70: ERROR:  could not load library
"/usr/lib/postgresql/postgis-2.0.so": /usr/lib/postgresql/postgis-2.0.so:
undefined symbol: GEOSHausdorffDistance
etc.
Is I do an ls on /usr/lib/postgresql/postgis-2.0.so, it exists.  Any guesses
as to what's going wrong?
(as postgres):
$ ls -l /usr/lib/postgresql/postgis-2.0.so
-rwxr-xr-x 1 root root 1411872 2011-11-01 09:56
Thanks,
Steve
(216) 635-3243 <tel:%28216%29%20635-3243>
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111101/355724b8/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111101/355724b8/attachment.png>
