[postgis-users] Slow Query Times for Split Tiles
elliott
elliott at cpi.com
Tue Nov 1 14:42:01 PDT 2011
I know that the tiles are indexed. How do I tell if the query is using
the index?
On 11/1/2011 5:34 PM, Pierre Racine wrote:
> Did you check if your query is using the index?
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of elliott
>> Sent: Tuesday, November 01, 2011 4:48 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] Slow Query Times for Split Tiles
>> On 11/1/2011 4:27 PM, Mateusz Łoskot wrote:
>>> On 1 November 2011 20:23, elliott<elliott at cpi.com> wrote:
>>>> Should splitting raster files into tiles increase query performance?
>>>> I have a two 1201x1201 raster tiles that were loaded by the following
>>>> scripts:
>>>> raster2pgsql.py -a -r N37E126.hgt -F N37E126 -t srtm3 -s 4326
>>>> -k1201x1201> srtm.sql psql -f srtm.sql TEST
>>>> raster2pgsql.py -a -r N37E127.hgt -F N37E127 -t srtm3 -s 4327
>>>> -k50x50> srtm.sql psql -f srtm.sql TEST
>>>> Querying these raster files appears to produce approximately the same
>>>> timing results. Should the 50x50 have better performance than the
>> 1201x1201?
>>>> Taking almost 3 minutes to query 10000 points seems to be very slow.
>>> Do you query tiles or points (what points?)?
>> Querying tiles for altitudes at lat/lon pairs.
>>> Do you measure itme of only query only or query and raster blob
>>> processing/rendering?
>> Time is for query only.
>>> What's your actual SQL command?
>> This query is run for 10000 lat/lon pairs -
>> select ST_Value(rast, ST_Transform(ST_SetSRID(ST_Point( lon,lat), 4326),
>> ST_SRID(rast))) from srtm3 where filename='filename'
>> AND ST_Intersects(rast, ST_Transform(ST_SetSRID(ST_Point(lat,lon),
>> 4326), ST_SRID(rast)));
>>> Best regards,
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
