[postgis-users] ERROR: Error performing intersection.
Andreas Forø Tollefsen
andreasft at gmail.com
Fri Nov 4 05:34:26 PDT 2011
What could be the reason for this query:
SELECT p.gid, array_to_string(array_agg(distinct(CASE when (g.cowgroupid <>
0) then g.cowgroupid end)), ';'), CAST(SUM(ST_Area(ST_Intersection(p.cell,
g.geom))) AS decimal (6,4)), g.type, g.startyear, g.endyear
FROM priogrid p, "geoepr-20100212-1248" g WHERE ST_Intersects(p.cell,
g.geom) GROUP BY p.gid, g.cowgroupid, g.type, g.startyear, g.endyear;
to produce the following error?
********** Error **********
SQL state: XX000
Andreas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111104/57ab931c/attachment.html>
