[postgis-users] Problems with backing up and restoring Tiger Geocoder database
Paragon Corporation
lr at pcorp.us
Wed Nov 9 14:06:48 PST 2011
Rene,
My guess is you probably did an SQL backup instead of a compressed or tar
backup.
I've had this issue before when backing up with pgAdmin and the reason is
because it defaults to sql backup I think. I forget what the switch is
you can check our backup /restore cheatsheet for reference.
http://www.postgresonline.com/downloads/special_feature/postgresql90_pg_dump
restore_cheatsheet.pdf
(you want -F c -b
pg_restore can only be used to restore tar or compressed backups.
We restore the tiger data all the time to various servers so no issue there.
Leo and Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of René Fournier
> Sent: Wednesday, November 09, 2011 2:10 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Problems with backing up and
> Since building the Tiger Geocoder database from the source
> data is so time-consuming, I'm trying to capture the result
> (the ~90GB spatially aware database) so that I can simply
> restore, in case I need to rebuild the server. Should be
> simple, but every time I pg_dump and attempt to pg_restore, I get
> pg_restore: [archiver] input file does not appear to be
> a valid archive
> So, just wondering what I'm doing wrong? Or, put another way,
> what are the steps to dump the given database and restore it
> to another server running Postgresql90 and PostGIS 1.5.3? Thanks!
Rene
> postgis-users mailing list
