[postgis-users] Linux installation
Josh Jordan
joshjordan at robotjosh.com
Fri Nov 11 07:46:47 PST 2011
If you try to compile postgis 2 in a debian system, "apt-get build-dep
postgis" helps a lot
On Fri, Nov 11, 2011 at 7:33 AM, Mathieu Basille
<basille at ase-research.org>wrote:
> Dear Steve,
> As a complement to what Paolo said: I don't know about other distros, and
> I'll talk only about Debian which I use on a daily basis. A fresh Debian
> install (stable or testing or even sid) is not up-to-date in terms of GIS
> packages. Examples:
> - QGIS: last release is 1.7; Debian only provides 1.4 in all flavours of
> Debian;
> - GDAL: last release is 1.8.1; Debian provides 1.6 for stable, 1.7 for
> testing, and 1.8 for experimental, which is hardly installable due to
> dependency troubles (but they are working on it).
> I don't mean that Debian is a bad choice... Especially since I'm using it
> as my primary platform! It is indeed very good for many reasons. But if you
> want cutting-edge GIS tools, you'll need to tweak Debian a bit. For
> example, you can find how to install most recent QGIS versions here:
> http://www.qgis.org/wiki/**DownloadFr#Debian<http://www.qgis.org/wiki/DownloadFr#Debian>
> Back to PostGIS now. If you want the latest stable release, which is
> 1.5.3, a simple
> [sudo] aptitude install postgis
> under testing should do the trick. If you want to run stable (which is a
> good choice), you can use some apt-pinning to be able to install packages
> from testing, or you can use PostGIS 1.5.2 with the previous command line.
> If you're interested in the development version, i.e. PostGIS 2.0 with
> raster support, it'll be slightly more complicated to have a complete GIS
> platform (but not impossible I guess). For instance, you'll need to compile
> everything by hand from GDAL 1.8 to PostGIS 2.0 through QGIS... But in this
> case, there is no GIS-related reason to use Debian: compilation should be
> the same under any Linux distro, so just pick up the one you like (or the
> one for which you have people to help you around).
> Hope this helps,
> Mathieu.
> Le 11/11/2011 04:19, Paolo Cavallini a écrit :
>> Il 10/11/2011 17:41, Steve.Toutant at inspq.qc.ca ha scritto:
>>> Hi,
>>> Sorry for cross-posting on several lists, but we are in the process of
>>> taking some important decisions, on the OS to use...
>>> For several years we have mapserver, gdal and Postgis, etc... running
>>> on a Windows server.
>>> We plan to migrate our GIS tools from the Windows server to SUSE Linux
>>> Enterprise Server 11.
>>> I heard bad comments on using SLES with mapserver, postgres/postgis,
>>> gdal, etc...Taht the installation of these tools was a pain compare to
>>> OpenSUSE or UBUNTU.
>>> Comments on using and maintaining GIS infrastructure with SLES 11
>>> would be very appreciated.
>>> Hi all.
>> I think having GIS packages ready and updated is the most important
>> thing in choosing a Linux distro. Debian should be the best, as it is
>> updated and wdely used and tested.
>> All the best.
>> Paolo Cavallini
>> See:http://www.faunalia.it/pc
>> This body part will be downloaded on demand.
> ~$ whoami
> Mathieu Basille, Post-Doc
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> + Centre d'Étude de la Forêt
> Département de Biologie
> Université Laval, Québec
> ~$ info
> http://ase-research.org/**basille <http://ase-research.org/basille>
> ~$ fortune
> ``If you can't win by reason, go for volume.''
> Calvin, by Bill Watterson.
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111111/bbd3efbc/attachment.html>
