[postgis-users] ST_ShortestLine(r.geom, m.geom) confusion - better limiting point to nearest line results
Chris English
sglish at hotmail.com
Mon Nov 21 17:09:58 PST 2011
Thanks Phil for your response. The below does greatly reduce number of rows created through theinner join.The "shortestlines' unfortunately seem to radiate from the center of town.
create table summit_final_drop asselect ST_ShortestLine(nearestgeom.intersection_geom, b.geom) from summit_parcels_centroid as b, (Select a.*,
ST_Distance(a.intersection_geom, b.geom) as dist from summit_roads as a, summit_parcels_centroid as b order by dist asc limit 1) as nearestgeom;Query returned successfully with no result in 12281 ms.
Changing asc limit 1) to desc limit 1) and all segments come from the edge of as if a fan.
I return to your suggested order ST_Shortestline(point, line) - though I was concerned that this will flip my start/end points for the segment with an eyetoward the final part, pg_routing
create table summit_final_drop_4 asselect ST_ShortestLine(b.geom, nearestgeom.geom) from summit_parcels_centroid as b, (Select a.*,
And result is same radiation from the center.
Running St_ShortestLine twice:
create table summit_final_drop_7 asselect ST_ShortestLine(nearestgeom.geom, b.geom) from summit_parcels_centroid as b, (Select a.*,
ST_Shortestline(a.intersection_geom, b.geom) as dist from summit_roads as a, summit_parcels_centroid as b order by dist asc limit 1 ) as nearestgeom;
Fan again. So, something about the order that roads are compared to points. I'll keep poking around.Chris
Date: Mon, 21 Nov 2011 22:13:33 +0000
Subject: Re: [postgis-users] ST_ShortestLine(r.geom, m.geom) confusion - limiting point to nearest line results
To: postgis-users at postgis.refractions.net; sglish at hotmail.com
Hi Chris
You need an inner query that selects the closest line segment and use that geometry in the shortest line query
Select shrtest line(p.the_geom,nearestgeom.thegeom) from
Points p,
Select a.*, st_distance(a.the_geom, b.the_geom) as dist from roads a,points b order by dist asc limit 1) as nearestgeom
Hope this is readable as sending from phone.
Chris English <sglish at hotmail.com>;
To:
<postgis-users at postgis.refractions.net>;
Subject:
Sent:
Mon, Nov 21, 2011 9:00:47 PM
Hi all,
My goal is to model electric distribution in a municipality with 8.4, PostGis 1.5 and pgrouting.
I clipped roads and parcels from state level (roads) and county level (parcels) to get roads and parcels fora municipality resulting in two tables:
summit_roads (306 rows) and summit_parcels (6874 rows) . The roads table generally conforms to the layout of electric distribution.I then extracted a centroids table from parcels to try to develop the 'final drop' line segment, the last bit of wire fromdistribution wire (roads) to a home or business with the final goal to then join to final drop to roads for end to end distribution.
explain create table summit_final_drop asselect Distinct ST_ShortestLine(r.intersection_geom, m.geom) as
final_drop_geom,r.sld_name,r.measured_l,m.pams_pin,m.mun,m.block,m.lot,m.qcodefrom summit_roads as r,summit_parcels_centroid as m;
This code resulted in 2,109,000 rows , essentially centroid to every line point as against whatI was expecting.
Suggestions appreciated.
Thanks,Chris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111121/abcafd2c/attachment.html>
