[postgis-users] ST_Mapalgebra
Bborie Park
bkpark at ucdavis.edu
Tue Nov 22 08:27:39 PST 2011
Joan (and anyone else using 2-raster MapAlgebra),
You don't need to specify ::double precision in your expressions.
Under the hood, your expression is wrapped with parentheses and
::double precision. So, if your expression was
CASE WHEN rast2 > rast1 THEN rast1 ELSE rast2 END
Internally, the expression becomes
SELECT (CASE WHEN rast2 > rast1 THEN rast1 ELSE rast2 END)::double precision
-bborie
On Tue, Nov 22, 2011 at 6:51 AM, Joan <wamaithajoan at gmail.com> wrote:
> I have tried it and it works. Thank you Pierre.
> On 22 November 2011 15:33, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
>> > I have used ST_MapAlgebraExpr but I get the error below.
>> > select * from (select ST_MapAlgebraExpr(kb.rast, kb1.rast,
>> > 'kb1.rast+kb.rast') as
>> > rast from kb_dsm_clip kb, kb_dsm_clip100 kb1) as r1 limit 5;
>> > ERROR: missing FROM-clause entry for table "kb1"
>> > LINE 1: SELECT (KB1.RAST+KB.RAST)::double precision ^
>> > QUERY: SELECT (KB1.RAST+KB.RAST)::double precision
>> Try this instead:
>> SELECT ST_MapAlgebraExpr(kb.rast, kb1.rast, 'rast1 + rast2') as rast
>> FROM kb_dsm_clip kb, kb_dsm_clip100 kb1
>> WHERE st_intersects(kb.rast, kb1.rast)
>> 1) There is no need for a subquery
>> 2) You must refer to the raster using 'rast1' and 'rast2', not their real
>> names
>> 3) I don't know if your rasters are tiled but it is always a good idea to
>> restrict the process to intersecting footprints.
>> Pierre
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
