[postgis-users] Typmod and triggers
Jose Carlos Martinez
jomarlla at cgf.upv.es
Tue Nov 22 10:53:16 PST 2011
Hi all,
Im using PostgreSQL 9.1 and PG 2.0 under MS Windows.
Lets say I have a tabla A with a geometry column 'geom' of type
geometry(MultiPolygon, 23030).
then I wrote a trigger (BEFORE INSERT ON, FOR EACH ROW) that changes:
New.geom:= ST_GeometryN (New.geom, 1).
After inserting a row:
insert into A (geom) values ('SRID=23030;MULTIPOLYGON (((0 0, 10 0, 10
10, 0 0)))'::geometry);
I got a row inserted in this table with a POLYGON type!!
And Viceversa:
I wrote a trigger that change: New.geom:= ST_Multi(geom);
then I insert:
insert into A (geom) values ('SRID=23030; POLYGON ((0 0, 10 0, 10 10, 0
0))'::geometry);
and then PostgreSQL checks again the typmod geometry before the trigger
and it is not possible to insert such a row.
In PG8.4 without typmod everything worked fine.
If this is the expected behaviour then I think typmod is adding some
important limitations that PostGIS didnt have before.
If not then what Im doing wrong? can i fix it?
PD: Sorry if this problem was already post in the email list..i couldnt
find it though.
Thanks in advance,
Best,
Jose
