[postgis-users] no output from select in psql
Andreas Forø Tollefsen andreasft at gmail.com
Tue Nov 29 07:16:36 PST 2011
Did you close the query in the command line?
SELECT * FROM table;
; might be what you are missing.
2011/11/29 jdmorgan <jdmorgan at unca.edu>
>  Hello,
> I am sure this is something quite simple but I cannot figure it out.  I
> am connected to PostgresSQL via putty.  I am trying to run statements
> e.g. SELECT * FROM table in the psql command line utility.  However, when
> I run the statement it does not return any results to the putty window.  I
> know there is data in the table through.  Also, no error is thrown.  Any
> help would be appreciated.
> Thanks,
> Derek
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111129/92a92369/attachment.html>
