[postgis-users] Batch geocoding (~2 mil addresses)
Johnathan Leppert
johnathan.leppert at gmail.com
Tue Nov 29 21:38:20 PST 2011
Hi Ravi,
There is a thread about the tiger geocoder performance from awhile back you
might want to look into. I had to do this before with about 1M addresses
and ended up creating an ec2 instance for each state and sending addresses
with that state to that specific host (using a simple regex to match state
in an address line). Somewhat expensive, but got the job done quickly.
Johnathan
On Tue, Nov 29, 2011 at 9:18 PM, Ravi ada <raviada at dobeyond.com> wrote:
> Hello All,****
> I have been fighting with PostGIS for the last week or two to geocode
> about 2 million addresses. Here are the challenges that I am facing.****
> **1) **I sorted the addresses by zip, address, city to group the
> similar addresses together.****
> **2) **So far I have seen only 50% of rating zero, that means
> perfect match.****
> **3) **Some addresses have Suite# or Apt# in address line 1. Geocode
> function takes longer time for such addresses****
> **4) **Addresses that are on the interstate, may be on the service
> road. These are taking longer to code.****
> **5) **Getting syntax errors on line_segment function when
> processing some addresses that have additional data in parenthesis and a
> period. For example "5727 FM 3097(HORIZON RD.),ROCKWALL,TX,750327786" ****
> **6) **I am using batch updates selecting the addresses per state to
> reduce the size of the batch. I used straight SQL update as mentioned in
> the documentation, and wrote a function to call geo code for each address.
> In both cases the query ran for more than 6 hours and never been able
> finish successfully. If I kill the query, nothing gets updated to the
> address table because the whole transaction is killed and not committed.**
> **7) **I am running this on Ubuntu 11.10 and postgresql 9.1 on a
> virtual machine on 8GB i5 machine. I know the resources are very less for
> such a task.****
> My questions are****
> **1) **How other people are geocoding so many addresses, what is the
> best way to do it, knowing that we may not have fully normalized addresses.
> **2) **How long it should take to geocode about 2mil addresses.****
> **3) **What does it mean if the rating is non-zero, and more than
> 50. Do we get the distance wring for such addresses?****
> **4) **What is the recommended hardware configuration? We need to
> geocode these addresses only once, and periodically to the delta that we
> get every month. ****
> Thank you so much for all the efforts that you guys are contributing to
> the project. Any help with my questions would greatly be appreciated.****
> Thanks****
> Ravi Ada****
> postgis-users mailing list
*Johnathan*
Software Engineer
San Francisco, California
*Follow me on Twitter: @iamleppert <http://twitter.com/#!/iamleppert>*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111129/552d946e/attachment.html>
